purfling lines...
http://www-.luthiersforum.com/forum/viewtopic.php?f=10101&t=48834
Author:  sdsollod [ Tue Jan 10, 2017 4:48 pm ]
Post subject:  purfling lines...
How were these purfling lines installed? A gramil could work on the sides with edges, but not sure about the other side where a gramil wouldn't reach...
Author:  Rod True [ Tue Jan 10, 2017 5:14 pm ]
Post subject:  Re: purfling lines...
CNC? Either that or a really good jig to follow.
Author:  Aaron O [ Tue Jan 10, 2017 5:39 pm ]
Looks like an inlay.
Author:  DennisK [ Tue Jan 10, 2017 5:50 pm ]
Gramil could work. The straight lines would be easy enough to do with a knife and ruler. But I think Aaron is right, and the triangles were inlaid rather than created in-place. The curl in the maple inside the triangles doesn't look exactly the same as the curl outside... though it's close enough that I'm not sure.
If they are inlays, then they were probably done while the bridge was still rectangular, and then it was carved to fit the inlays rather than the other way around.
Author:  JoeM [ Thu Jan 12, 2017 11:08 am ]
If I was making that part I'd be thinking "router templates", there would be some careful knife and chisel work at the corners to get the sharp points no matter how you approach it I think.
Author:  Clay S. [ Thu Jan 12, 2017 12:32 pm ]
Some people have a steady hand. I'd bet Doug Ingram wouldn't have a problem with it.
Author:  Joe Beaver [ Thu Jan 12, 2017 2:57 pm ]
I have never done bridge inlays but if I was to do one I would do it like my headstock purfling inlay.
I would use the Stew Mac dremel base with edge guide. I would use a board as a straight edge to cut the straight channel. The points would have to be finished off with an exacto knife.
Author:  Allen McFarlen [ Thu Jan 12, 2017 3:33 pm ]
Dead easy with a CNC.
Author:  Bri [ Thu Jan 12, 2017 6:05 pm ]
On Furniture, this would be called stringing.
Typically it would be done with a tool called a scratch or a scratch cutter.
Lie-Nielsen and Veritas both make various stringing tools.
Author:  phil [ Sat Jan 14, 2017 1:36 pm ]
CNC's are cool . . . and expensive . . . and I bet that job could be done with a Dremel and the Purfling/Soundhole Router Guide from StewMac.
